I've just installed windows 10 and Microstation V8i (08.11.09.459). When I open a drawing it display as above. If I open the same dgn file on a different computer it display correctly.
Please help in this regards
try setting the following variable:
QV_D3DVERSION = 9
Timothy Hickman
Main: 877 627 3772|
Is this a Microstation variable and where do I configure it. Thanks for the reply
go to the workspace pulldown and select configuration. The dialog that opens has a create button. Create the variable, set it to 9, save the changes, then exit MicroStation and restart.
Thanks Tim it works.
Proppie
