In Microstation v8i I have an mdl app called SWA that drew a rectangle (in 2d or a cube in 3d) showing the extent of the solid working area. Does anyone know a way of doing this in Connect? It's really useful for explaining to people why they are having problems with geometry that's way outside the SWA.
Duncan
Brilliant. Now I understand. Thanks Brian. That's what I'm proposing to do.
For some more in depth information regarding the SWA you may find the following articles useful:
https://communities.bentley.com/products/microstation/w/microstation__wiki/2972/using-the-solids-working-area-in-microstation-v8-cs
https://communities.bentley.com/products/microstation/w/microstation__wiki/2898/your-solids-working-area-global-origin-working-units-and-you-cs
David,
The two links you provided refer to rather outdated information with regards to SWA (15+ years old).
The explanations from Brien Bastings are much more up to date and relevant to the current implementation of the SWA.
Regards,Ron
