Hi, would you advise on the best way to plot in Microstation v8i using a "live" coordinate grid/template please instead of having to physically create overlays for each area. Thanks
Hi Michelle - you will usually get a faster response by posting your query in the software's community, rather than a general forum. I am moving your post to the Microstation forum. Someone should respond shortly.regards,
Duncan Brown
could you draw an example?
I think your asking can we make a map grid ( neat lines) like in mapping packages and label the easting and northings around the edges if so most DOTS give these away as macros in old Basic, VBA and MDLs if you cant find one from your DOT, then PM me and I can pass along our local DOT one we use regularly..
Lorys
click on the link below where it says click to link to PM me, this will open a means write more lengthy explanations , instructions and uploads back and forth if first attempts for you dont work.. like a private thread...
