I am trying to download the Connect Edition of Powerdraft, however in the download list there are a numbe rof updates ranging from 1558MB for Update 4, 1328MB for Update 5 then Updates 6, 7 & 8 are all just 2MB.
So should I download Update 4 then once installed add every update thereafter or jump to Update 5 then carry out the later updates. 2MB is clearly not large enough for a software download!
Many thanks
Keith
There should be PowerDraft CONNECT update 9. 10 will be available soon. I would suggest using the highest number available due to bug fixes etc.....
From Update 6 on the installer loads only those components needed for installation on your machine. Up until Update 5 the whole package was downloaded.
Thanks Ian, I think this sort of thing should be much clearer on the website to save someone who is pretty proficient generally with IT having to ask a simple question!
Thank you, that is helpful, I'll start with Update 5 then install the other updates...
Keith. If you have never installed PowerDraft then opt for CE9. It will download the entire package and the previous updates. Then when Ce10+ come out opt for the update option
