Why are referenced elements grayed out when I set them to black in the level manager? I can change the line weight just fine. I can change the color to red but the referenced elements change to pink instead. What is going on?
Thank you! Just to reiterate: From the "5 Improvement Sheet" Model (where I was having the issue) go to Attach Tools/ Reference and then highlight the appropriate reference file and go to Properties/ Adjust Colors and from here adjust the Transparency to 0.
Seems so simple now; I was hung up on the Level Manager and forgot about this other tool.
Answer Verified By: Michael Smith
