Does anyone know of a way to get materials to copy from a dgnlib to a DGN file on use?
I have many materials applied to meshes via element templates and others by level and they are not copying locally, even using the MS_LOCAL_MATERIALS config variable. I really don't want to be having to provide the client with a dgnlib just to see materials for the dgns we produce.
Hi Mark,
You could create a new palette and import all the materials you are using from the dgnlibs into it.
Jerry
Answer Verified By: Mark Shamoun
Thanks Jerry,
So if i had a palette in my seed with all my dgnlib materials, all materials would be read directly from dgn?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Yes that would be correct you would have local copies in that palette.
Excellent, thanks Jerry!
Hi Jerry, unfortunately no luck after making a local copy.
What im trying to do is have a self contained DGN that will allow users of Microstation without our material dgnlibs to see the materials
Any ideas?
