I'm trying to clean up some older details, and the text and dimensions are just a mess. Is there some way to see what annotation scale has been applied to an element? I know that Properties will show "Is Annotation", but I want to go one step further and see what that annotation scale factor IS.
Thank you.MaryB
If you use the old legacy Analyze Element keyin the annotation scale will be listed under the details tab:
Answer Verified By: MaryB
I forgot all about that one!That's not in the interface at all, is it? I mean, it's only available by keyin, correct?
Thank you!!
MaryB
