How to know if transformation between gcs datums is supported in Microstation? Is there any list of supported transformations?
Also, i would like to inquire if i created a custom coordinate system(using Bentley Map), Can entities be readily transformed to any other datum or ellipsoid in Microstation?
Thanks.
Ron
MicroStation has the ability to reproject or transform between different Geographic Coordinate Systems defined within each of the models you might select or reference.
Geographic Coordinate Systems > Reprojecting Design Data
The following is a list of the Projections Supported but if you have defined a custom coordinate system within Bentley Map it can also be used in MicroStation.
Workflow for Using Custom Coordinate Systems
I hope this information is of assistance.
Hi Andrew,
Thank you for the links. I'll have a look into them and come back if i have further questions.
Andrew,
The links seem to be broke.
Thanks for reporting, the links Andrew provided are to the MicroStation Help file, you can search the help using the text in the links, or navigate to the page
Home > Setting Up the Environment > Geo-Coordination > Geographic Coordinate Systems > Reprojecting Design Data
Home > Setting Up the Environment > Geo-Coordination > Projections Supported
Home > Setting Up the Environment > Geo-Coordination > Geographic Coordinate Systems > Workflow for Using Custom Coordinate Systems
Carl Myhill
Technical Support Engineer
Bentley Systems
