Since we have new PC's I downloaded the newest version of Powerdraft Update 9 via the Connection Client. Today I tried to start Powerdraft but it failed to start.
I've read quite some solutions, like install .NET (already installed), manage firewall settings, etc. None of them worked so far.
I'm using this system:
- Windows 10 pro, Intelcore i7-8700K 3.7 GHz 64 bit
- Nvidia Quadro P4000
Thanks in advance,
Hi Jordy,
what Windows version do you use? The latest April Update? There is known (confirmed by Microsoft) bug in the latest Windows that causes crash of some application, including Bentley ones.
For more information about this MicroStation issue see wiki article.
With regards,
Jan
Hi Jan,
Thanks for your reply. The windows version is 1803, installed on the 26th of may.
I'll try the solution in your link!
Jordy Baert said:I'll try the solution in your link!
Because it's expected Microsoft will release bug fix this Tuesday (tomorrow), in my opinion the best solution is to do nothing and to wait whther the monthly update will resolve the problem with PowerDraft ;-)
Thanks Jan,
I'll wait instead, thanks again for your help.
Jordy Baert said:I'll wait instead
Unfortunately, as explained in this recent information update, the problem will be not solved in the current Windows updates :-(
