I know you can use the measure length tool to quickly measure a line, curve, etc. But it there a command or macro that you can use to select any number of lines, curves, etc and have the total length added up and displayed?
dcfox341 said:But it there a command or macro that you can use to select any number of lines, curves, etc and have the total length added up and displayed
You should select first all the desired elements and then you can use Measure\Measure Length to get the total sum:
Hope this was what you're looking for.
José
Answer Verified By: dcfox341
Thanks José
you should use the utility data clean up remove duplicates before you attempt measure lines and arcs with powerselector global or by level as you will measure more than you expect.. I found this with a kerblines and shapes that came from autocad as they make fills as separate elements so we have twice the polygons... also errors creep in with copy lines in drawings so I always run the delete duplicates from the data cleanup tool before I start measuring bulk elements... if I use a small crossing window I can see how many elements on screen and compare it with the bottom button window ( forgot its name) as it tells you the number of elements selected ...
Lorys
