How to set ON Use Seed File Global Origin in DWG Options dialog by using variable configuration?
Would you be able to clarify exactly what it is you are performing. Is this relating to a Save As DWG workflow? Specifically, the DWG Seed File being used? Maybe you could provide the exact version of MicroStation you are using along with screen captures showing what you are trying to perform. We can then assess what might be the best option for you.
Thanks to your reply, my using MicroStation Version is V8.05, and my DGN seed file has Storage Center Point: 500.000,1.000.0000. When i checked option: Use seed file global origin, and then saving dwg file (Cad14) to dgn is my dgn file has the same Storage Center Point (500.000,1.000.0000) but not checked, my dgn file has Storage Center Point: 0,0. I programme software converting dwg to dgn, so i want check it by using variable configuration.
p/s: I can't find out variable configuration relating to this configuration in this link: communities.bentley.com/.../microstation-connect-edition-configuration-variables
MicroStation V8 2004 Edition (08.05.xx.xx) is quite an old version and would not be certified or supported for use with current versions of Windows.
https://www.bentley.com/en/desktop-applications
The list of configuration variables you have posted here is for MicroStation CONNECT Edition. It would be suggested that you should upgrade to a current release of MicroStation which would either be MicroStation V8i (SELECTseries 4) or CONNECT Edition.
I do not believe there is a specific configuration variable to define this "Use Seed File Global Origin" setting but any of these specific settings you have here can be save to a DWG Settings File. This settings file can then be defined automatically in whichever project it is being used within.
https://communities.bentley.com/products/microstation/w/microstation__wiki/31061/how-to-save-dwg-settings-for-opening-and-saving-dwg-files
Thank you for your supporting, i try using this configuration variable to see what will change.
