Hi.
I have many different categories & sub categories of multi-line, but some are mixed in level & attributes.
My question: Is there any way to select them based on a specific width, so I can keep them on the correct level or category?
Which version (e.g. v10.x.y.z) of MicroStation, or other product, are you using?
Al Maraghi said:Is there any way to select them based on a specific width, so I can keep them on the correct level or category?
Have you considered Element Templates, that may help bring order to chaos?
Hi Al Maraghi,
Al Maraghi said:so I can keep them on the correct level or category?
I don't believe Category is a terminology in Microstation, it's possible you're referring to Class?
Have you check Element Selection? With this you can select by any available way like weigth, multiline or even by element template:
If you're missing some options RMB (Right mouse button) and select the desired selection mode:
After your selection been made easily you can change levels.
Is this what your looking for?
José
Thanks for your responsible.
Iam using Microstation 2004 Edition.
You can check the image will explain it more clearly.
Thanks again
Hello Dear,
well Its Microstation 2004 Edition version 08.05.02.70
I tried many ways, but unfortunately couldn't, some are same color, weight, style. The only difference is the width.
i uploaded an image for a part of my file to show the exact situation.
Thanks for your replay,
Is this made by colour and disregarding the levels?
And you want to place the red ones in one level, yellow ones in another and so on?
If that's so you can select the elements by colour and then change the level.
Al Maraghi said:Iam using Microstation 2004 Edition.
Even in 2004 Edition you can select by any available option in Power Selector, like colour, width and multiline.
