I need to pull measurements for each dropdown. The way I've done this in the past is to select all drop downs and ctrl+I and literally type every measurement into an excel file. Is there a faster, easier, and more accurate way of getting this information for example a downloadable measurement list of selected items? Scrolling through 500+ measurements and writing them all down is not only time consuming but also prone to failure with a measurement here and there.
3617.DGN Example.dgn
Carl Krumroy said:Is there a faster, easier, and more accurate way of getting this information?
FlexiTable makes it fast and easy. Here's an Excel workbook with your line lengths, courtesy of a few minutes work for FlexiTable.
Krumroy-lines-3617.DGN Example.xls
