50% of the time when applying a GCS to a file, u10 crashes.
Hi Duncan,
any specific GCS?
is there any Exception history folder created? https://communities.bentley.com/products/microstation/w/microstation__wiki/8832/how-to-quickly-find-and-collect-exception-logs-and-minidump-files
Maria
Maria Garcia
Hi Maria,
i will collect an exception the next time this happens,
This has been with the OSGB 2002 GCS but also when applying tranforms from file.
Yes, happened to me the other day, has nothing to do with the actual coordinate system, that's a Bentley tactic to get you chasing your own tail. Worked fine after I ran chkdsk, booted, opened same file up again. Connect crashes a lot. It is more or less not ready for prime time. I generally am using the GCS from seeds, so I don't perform this operation very often.
