When I go to the fufillment center, the only microstation files available are connect and a 32 bit version of v8i from 2016.
Is anyone else having this issue on the fufillment website
When you perform a search for the versions of MicroStation available for download it should show the following list.
The first three are the latest releases of MicroStation CONNECT Edition Updates 8, 9 & 10 which are all 64 bit applications.
The last is the final release of MicroStation V8i (SELECTseries 4) 08.11.09.829. This is a 32 bit application but is fully certified for 64 bit versions of Windows up to 10.
https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/30658/software-download-instructions
Yes, that is correct. Nothing recent has been removed.
I don't see this. I had to restore my system and reinstall but V8I SS4 is no longer showing as an available product
Hello Lynwood,
MicroStation V8i versions are not available on the Software Downloads page anymore. We often archive old builds so that Software Downloads is not cluttered, and it is easier for users to find our latest and greatest products.
Please log a service request and we'll send you the download link. In the SR please provide some quick answers to the reasons behind why you may still be using V8i version and have not adopted the CONNECT Edition yet?
Regards,Anu
AnuKuu said:provide some quick answers to the reasons behind why you may still be using V8i version and have not adopted the CONNECT Edition yet?
I can't answer for Lynwood, but some of our reasons are:
1. Largest client is not working with CONNECT and is not requiring CONNECT drawings.
2. CAD standards/administration will need a complete re-work to fit CONNECT configuration.
3. Lingering concerns about functionality and stability.
4. Many, many projects still in V8i that will not be brought "ahead" to CONNECT/OpenRoads
5. Concern about the downtime/learning curve with a limited budget for training.
MaryB
