Hi All,
Can any one tell why do we can not measure surface area of smart surface in micro station?
Thanks !
Which version (e.g. v10.x.y.z) are you using?
V8i SS3
Santosh Rai, EngTech MICE, ACP, BQT
Senior Designer - Highways
Please also confirm the method you are using to measure the area, it may also be specific to the element your measuring.
May be you could post a dgn with the extracted surface your trying to measure for all to review / comment on.
In V8i SS4 I was able to use the Measure Area tool on a Smart surface
Carl Myhill
Technical Support Engineer
Bentley Systems
Hello Santosh,
I have just tried in MicroStation V8i SS3Created 2 Smart Surfaces, a simple one and a more complex, then from the Measure toolbox picked the Measure Area and selected the surface.With no problem I got an outcome for the surface area.What does your Smart Surface look like, could you provide an example so I can test?
René R. van den BrinkTechnical SupportBentley Systems Incorporated
unable to upload the file. an error occurs while uploading the dgn
