Hi All,
Can any one tell why do we can not measure surface area of smart surface in micro station?
Thanks !
Thanks Douglas for providing the file. We are currently looking into it to find out why the 1x1 is not showing the value in the measure area tool while the properties dialog does show the correct area. We will keep you posted.
Dan
Hi Duncan, I can't reproduce this issue with MicroStation CONNECT Edition and a fresh file with the same shape you described. Are you using any customised seed files by any chance?
Dan Eng said:We are currently looking into it to find out why the 1x1 is not showing the value in the measure area tool while the properties dialog does show the correct area.
I guess it's because the shapes are placed outside wokring area.
Working area:
Shape coordinates:
When moved to 0,0, the area is calculated correctly.
With regards,
Jan
