Microstation V8i (SELECTseries 4)
Version 08.11.09.829
Hi All,
Using the TEXT tool command only, is it possible to define a text frame around a text within its tool settings?
Thank you
Unknown said:is it possible to define a text frame around a text
MicroStation text styles offer a text background, which may do what you want.
This works fine for a single line of text, however multi-line text displays a box around each line. Is there a way of creating a box around a multi-line text node?
I want this
and not this
Any other suggestion/s?
Doh! As simple as that. Thanks very much Karl, i was looking in the wrong place and assuming it would be the FORMAT / JUSTIFICATION toggle on the left of your screenshot.
regards
Andy
But does it work properly with multiline text if you want it to look like a stamp with a back ground fill and a single rectangular frame around all the text see previous posts from HenryEduvie and me
Unknown said:This works fine for a single line of text, however multi-line text displays a box around each line. Is there a way of creating a box around a multi-line text node? I want this and not this
Lorys
Lorys said:But does it work properly with multiline text
Post an Idea!
Vote for Felix's Idea!
You mean this idea: microstation.ideas.aha.io/.../MS-I-398
I posted this about three years ago. The pictures didn't come through during ideation forum conversion but show exactly the above.
I already voted this ages ago
BTW in V8i ss10 I cant make text frame box text centre centre even from advanced and even from custom text style.. the text back ground fill works for just the text.
However it does draw the rectangular capsule around multiline text and it expands to suit the text if edited and the text only has the back ground fill but the box around the text doesnt so still doesnt work very well as a stamp if there is stuff behind...especially bad if used for multiline.. but single line big block tex like FOR CONSTRUCTION or DRAFT works pretty well... but still prefer my cells of stamps or tags text in title block...
