I created bunch of custom 3D line styles in V8i generation software and now they don't work in CONNECT. The way I build these line styles is I used meshes rather than solids (to keep them lighter size-wise) and it seems to be the reason why they are not recognised in CONNECT. Any reason why such defined line styles are not supported? If not, can this be fixed asap so we don't need to recreate
Below is a screenshot. V8i on the left and CONNECT on the right.
I'm running ORD update 4.
Regards,Krzysztof
It appears you have advised you are currently using OpenRoads Designer CONNECT Edition (Update 4). I would assume that you have upgraded from using InRoads V8i for this discussion? Thanks for the screen capture. Is it possible for you to supply a copy of one of these 3D line styles for us to try to replicate your issue between the two versions?
Sure, please find attached.
parapet example.rsc
Thanks for posting the *.rsc file, I am able to Place / View the 3D Linestyles using both MicroStation CONNECT Update 1o and OpenRoads Designer CONNECT Edition ( Update 4 ).
Have you checked the variable MS_SYMBRSRC is pointing to your *.rsc file ? https://communities.bentley.com/products/microstation/w/microstation__wiki/15379/adding-client-linestyles-to-the-element-linestyles-custom-list
Is the LineStyle available in the Attributes, LineStyle drop down list ?
Is the problem file specific ? What happens if you create a new file are you able to then place the 3d LineStyle ?
Also check the View Attributes ( CTRL+B ) and ensure 'Line Styles' is checked on.
In addition, the image supplied also shows different colors V8i compared to CONNECT, could it be that you are using a different Display Style / Display Rule, Color table?
Was a Template used and is this available in CONNECT ? You might also want to post onto the OpenRoads forum https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum#pi25841=1
Carl Myhill
Technical Support Engineer
Bentley Systems
Answer Verified By: Krzysztof Burdziel
That's very interesting. Thanks for checking it.
I believe the following Defect reported by another user may be related to this issue you're reporting.
Defect 975070: 3D Custom Line Style Containing Mesh Not Displaying If Located in DGNLib or DGN file.
"A custom 3D line style that contains a mesh within the Point Symbol is not displaying properly if it is being stored either in the DGNLib or DGN file. This had previously been working fine when it was stored within the RSC resource file and displays ok in either OpenRoads Designer V8i or MicroStation V8i. It is just when they moved to the CONNECT versions of these products with the line style in a DGNLib that the issue was noticed. This is required so all of the custom line styles are being stored in a DGNLib and are easily transferrable to their clients in DGN format files."
