Key In Place Active Cell
Via Key In or Key In script in Microstation V8XM/V8i i would like to set the Interactive flag and Rotate only in the Place Active Cell window, before placing the cell.
What does the Key In Command(s) look like?
  • Just wanted to add that you can use the "set item" key-in to change items in the toolsettings dialog.
    To do this:
    1. Start any tool
    2. Open the key-in browser and put in "set item toolsettings"
    3. You should see a set of named variables for the active tool
    4. You can set variables by using an "=" sign
    For example for this tool we could use the following:
    place cell icon  // start the tool
    set item toolsettings cellinteractiontype=1 // set the interactive type we want
    set item toolsettings celltypeinteractivetoggle=1 // enable the toggle
    This can also be done in the Customize dialog when making custom tools by right clicking in an empty area and adding item settings.
    Hope this helps,
    Gino
Reply
    To do this:
    1. Start any tool
    Hope this helps,
    Gino
