MS_REF_NEWLEVELDISPLAY Key In not working
I've seen users previously ask about new levels not being turned on from a reference and I've read for V8i you should use the key in MS_REF_NEWLEVELDISPLAY and set it to 1. My Key In does not accept the command and doesn't recognise it. Any ideas as to why ? and how I can fix this.
I have the situation where the levels aren't turned on but I also have the situation where the levels are on but you can't see anything. Both drawings have the same reference source.
  • You can control whether or not new levels are displayed in a reference file upon attachment. There is box in the Reference Attachment settings dialog. I believe the options available will be Always, Never or MS_REF_NEWLEVELDISPLAY. If you do not have the MS_REF_NEWLEVELDISPLAY defined in your workspace I do not know what the attachment would default to.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
Reply
