Microstation does not start after Windows update
After the update of Windows 10 last may, the connect versions of Microstation, Descartes and LumenRT designer, these won't respond anymore after startup at my laptop. However, they keep the processor @13% running. (quadcore - hyperthreathing)
I already tried complete re-install and  a -restoredefault of Microstation Connect edition update 10.
The 32-bit Powercivil and Microstation still function.
What are the options?
  • Hi,
    It's not clear what update did you install and what version is currently on your computer.
    The problem with original "Windows 10 Spring Update" was discussed in more forums quite widely. The issue is summarized in this wiki article.
    If you update your Windows automatically regularly, the problem should be solved now, because a bug relesed with the original update to version 1803 was solved by patch released by Microsoft about two weeks ago.
    With regards,
      Jan
    Answer Verified By: L. Tunissen
  • Thanks for the reaction,
    I did not googled enough to find this solution
    With regards,
    Leon Tunissen
    Van: Jan Slegr [mailto:bounce-FF247D2F-7ED5-451A-B5B2-A6FC5DBBF405@communities.bentley.com]
    Verzonden: dinsdag 7 augustus 2018 15:19
    Aan: SELECTserverandProductActivation@communities.bentley.com
    Onderwerp: RE: [SELECTserver and Product Activation Forum] Microstation does not start after Windows update
    If you update your Windows automatically regularly, the problem should be solved now, because a bug relesed with the original update to version 1803 was solved by path released about two weeks ago.
    With regards,
      Jan
    View online
    You received this notification because you subscribed to the forum.  To unsubscribe from only this thread, go here.
    Flag this post as spam/abuse.
    Afbeelding verwijderd door afzender.
    Op dit bericht is de proclaimer van de gemeente Helmond van toepassing www.helmond.nl/Actueel-Proclaimer
