Connect - Change variations parametric cells after place in model
Is it possible in MicrosStation Connect to correct variations or make a copy after inserting the parametric cell into a model? Example i want to rename my 3M to 7M and change the variables so all my 3M cells change in model.
Do you have to go back to the cell library and correct the cell and then update it in its model? I can correct the variables.
