Good day
I'm trying to figure out how to use the Place Table tool in MicroStaion/ OpenRoads Designer CONNECT Edition. We have a very standard format for some of our data and would like tables to be created exactly as they are in Excel.
Below is how the data looks in Excel:
Below is what it looks like if MicroStation attempts to preserve the formatting:
You can see that most of the text does not come through and not all of the row heights are preserved. The column widths are preserved.
Below is what it looks like when not preserving the formatting:
Am I missing something?
Kind Regards
Warren
That makes sense. I've always used that functionality for door & room schedules where that is the only thing on the sheet so it's not been a problem.
Sorry for the delay in responding further, I have been able to reproduce and Defect 937783 has been filed, it should respect the selected Table seeds formatting.
Just curious Carl, how's the OLE technology in Connect with Excel? Nice to link Excel sheets right to Microstation sheets, we certainly waited a long time before it got "good" in v8i. Haven't tried it since I started using this buggy Connect (r10).
Bob OLE technology may be an alternative option to using Tables for bring Excel data into your designs, if you find issues with OLE or other areas please raise a new forum post or Service Request for investigation. Thanks.
Thanks, Carl
