I have a weird display with MicroStation with all display styles, any idea?
MicroStation CE updt 10
Windows 10
Nvidea Qudro P5000
Latest drivers from Nvidea installed without success
Firstly on a copy of the file move the geometry to 0,0 and see if that fixes the problem. If it does you can use the GO= keyin to redefine 0,0 as a any coordinate you want then the object will reference using the desired coordinates but still be at the origin.
Change the origen but still having the same problem
Ctrl-B... turn on Clip Back.
