I have an issue, that cannot resolve myself.
Situation: DD Design.
Apply perpendicular constraints Line to Line - all OK; both lines and constraints symbol are visible.
Apply perpendicular constraints Line to Ellipse - line disappeared from the view; ellipse is visible, constraints symbol is visible.
If use "Modify and Resolve Constraints" tool, the ellipse is ON, line WAS invisible (anyway), and the constraints symbol is also disappeared.
Where I should look, to resolve strange behaviour.
Thanks.
Here you are how that is happening
Nikolay Vyglazov
Nikolay Vyglazov said:Where I should look, to resolve strange behaviour?
Please post an example DGN file here. Perhaps someone can analyse your DDD using the same version (V8i SS3) of MicroStation.
SteelSections.dgnthis is just sample, as I am practicing, trying to follow up the instructions for DDD
