I'm using OpenRoads Designer version 3 software. That has MicroStation connect with it.
I'm using "dimension element" tool and label line for length/angle. The settings I changed to bearing and dd.mm.ss. I have done save settings.
But, still the label callout show dd.dddd
Am i missing anything here with the new edition of software?
Suggestions please!
I think you need to create a dimension style...I'll double check at work tomorrow...
Lorys
Answer Verified By: Abhiram Supekar
The Setting can be found in the Dimension Style as Lorys points out. See https://communities.bentley.com/products/microstation/w/microstation__wiki/16130/how-to-remove-bearings-from-the-dimension-line-labels for the switch. Also expand the Element Dimensioning Tool Settings to see options.
Yes. that's true.I was missing with dim style setting. now it is showing dd.mm.ss
But, still the bearing not showing with N/E/S/W...!!
Thank you,
Abhiram
Yes, I did the dim styles settings.
The options for drop down are specific to where/how one wants to place the length/angle.
Northing Easting still not coming!
Does changing the design file settings for Angle Readout help ? ( File > Settings > File > Design File Settings )
Direction Mode : Bearing
see also https://communities.bentley.com/products/microstation/w/microstation__wiki/16959/how-to-enter-distance-and-bearing-angles-in-microstation
