Mstn Connect Update 10 Enter Data Fields turning white
In Microstation Connect Update 10, I am placing cells with "Enter Data Fields" in them.  When I enter information into an empty "Enter Data Field", it turns white.  When I edit an existing filled "Enter Data Field", it turns white. When I place a text with an "enter data field", it shows properly.  When I edit that text (edit single enter data field tool), the part of the text with the data field turns white.
This does not happen in Mstn V8i SS3.
Is there a setting that I am missing, or is this a bug?
--Thanks,
--Robert Arnold
