In Microstation Connect Update 10, I am placing cells with "Enter Data Fields" in them. When I enter information into an empty "Enter Data Field", it turns white. When I edit an existing filled "Enter Data Field", it turns white. When I place a text with an "enter data field", it shows properly. When I edit that text (edit single enter data field tool), the part of the text with the data field turns white.
This does not happen in Mstn V8i SS3.
Is there a setting that I am missing, or is this a bug?
--Thanks,--Robert Arnold
Hi JM,
If you want and have access to file a service ticket, you can do that and reference defect #940664.
--Thanks,--Robert
Hi Robert,
This issue has been fixed and will be available in upcoming release.
Abhay
Answer Verified By: RobertArnold
Hi Abhay,
Thanks for your help.
--Robert
Abhay,
I noticed the above issue of EDF turning white. You mentioned the fix being available in upcoming release. I am using Update 13 (Version 10.13.01.01). This is the latest version at the Bentley site. Is the resolution of the issue in the next update?
Thanks.
Please cancel my subscription as I have retired.
Dilip Bhandarkar
Hi Dilip,
From what I understand, this issue has been addressed in CE Update 14 (when ever it comes out). Of course, only user testing will be able to confirm that it works in all cases.
