Does anyone know how to enable the setting highlighted below - I cannot get this to show on my current configuration.
Which update of MicroStation CONNECT are you using?
Could it be that you are talking about Update 10 as this operation was removed due to performance issues.
https://communities.bentley.com/products/microstation/w/microstation__wiki/39101/resolved-issues-in-microstation-connect-edition-update-10-10-10-00-23
https://communities.bentley.com/products/microstation/f/microstation-announcements-forum/157672/microstation-connect-edition-update-10
Update 10
Stephen
GHD - Global Software Manager - MicroStation
MicroStation CE Update 16.3 | ProjectWise CE 3.4
Yes Andrew - Update 10 - thankyou
Hi Stephen,
As Andrew Bell already mentioned this functionality was removed due to performances issues.
This option is now hidden by Default in update 10 but You can set a configuration variable to enable model picker to be shown back if you did not experience any performances issues.
