[CONNECT] Reports Export Key-In
MicroStation Reports are great!  But, there's work needs to be done.
MicroStation CONNECT has key-in command REPORT EXPORT.  However, I can't work out what that key-in actually achieves.  It doesn't open the Reports dialog, and it doesn't seem to create a file.  Perhaps there are some additional arguments that aren't documented?
Is this a...
  1. Works As Designed (WAD)?  Surely not...
  2. Bug?
  3. Work in Progress (WIP)?
Parents Reply Children
