How do I group more then one item together in a 2D drawing in Connect Edition. In V8I it was easy to find under Edit, but I can not find it in Connect.
thanks
Top right icon. This is on the Home ribbon on the right hand side. You can also use the keyboard shortcut Ctrtl-G
Also it's really easy to search for a tool using the little search window F4 to move the cursor to it.
Oh thank you......
By any chance do you know where I can find the Key-in so I can make a button of the group?
Rebecca Vosters said:do you know where I can find the Key-in
Duncan already told you that!
