Hi
I want to copy and paste Microstation drawing objects into Microsoft Excel, as a "Picture (Enhanced Metafile)".
What I do is copy drawing objects and go into Excel, Paste Special as "Picture (Enhanced Metafile)". The problem is that it's not pasting as expected. It should (1) Paste as a vector image and not lose detail regardless of size in Excel, and (2) it should have a clear background.
What happens is that a raster image is pasted on a black background.
The equivalent, when done in AutoCAD works.
Is there a setting in Microstation V8i which enables me to to this.
Please try this:
1) From the dgn file , set view of the desired elements
2) Key in :oleserve viewcopy. Then select View by data click.
3) open Microsoft Excel program , right click and Paste special, > Paste >MicroStation View Object
I am getting this error when I try "oleserve viewcopy". I was Always under the Impression that I have admin Rights on that machine though. How could this be mended?
Please open MicroStation with Administration rights. go to Start > MicroStation > Run as administrator
