After undoing something, iam unable to redo it and it says in the notification centre nothing has been undone.
Please provide more information on the steps that you was taking prior to undo, or is it any operation for example if you place a line and then undo / redo does it disappear and reappear as expected ?
Is it file specific ?
Hi Carl,
Upon further investigation, it is only happening when placing and editing text and it is not file specific. Seems to work fine for every other task.
Even after creating a new file it still happens. Opening those newly created and existing files in v8i it works as expected.
Cheers
I've seen this also, seems limited to text commands. Add to the list.
