I was wondering if there is a way in microstation to alway show the vertices? Because quite often I want to pick an element and look at the vertex with some tool, but when I click on the tool I want to use, the vertices is invisible again..... In short terms I want the vertices to always be visible. Is that possible?
Hi P?l o
I am not sure I understand you correctly.
Do you mean vertex or handles in an element?
If you mean handles you can enable this on the element Select dialog by just pressing on disable handles button, once this is done the button below (Select handles) gets activated. See screen shot
If this is not what you are looking for, please maybe attach some screen shot or example file
Maria Garcia
Hi Maria, and thanks for the respond, unfortuantly that is not what I was looking for.
I am not sure if I mean vertex or handles as I am not 100% sure whats the difference between the two...
I have attached some images that shows what I mean. Image 1 show a group of selected elements with its corresponding vertices, but when I then change the tool I want to use, the vertices goes invisible eventhough the elements are still selected, see image 2.
I want that the vertex(or handles?) are always visible.
Any suggestions?
pål o said:am not sure if I mean vertex or handles as I am not 100% sure whats the difference between the two...
Microstation has handles, Autocad has vertex.
The useful tip that was given is for selection only.
José
Thanks Jose, then I know the difference :) But do you have any idea on how to make the handles visible at all time?
You could create a custom linestyle with a point symbol at each "end" and "corner".
MaryB
