Is there any way to convert suppliers 3d Model into hollow model with only the outline of the equipment visible and unwanted meshes and lines should be deleted?
Narayan Kavinatamai said:only the outline of the equipment visible and unwanted meshes and lines should be deleted?
Define 'unwanted'. Under what conditions do you consider an element to be unwanted?
For what purpose will you use the 'hollow model'?
It's going to depend on what the suppliers mode is like. Is is all solids or a mesh or a mixture? Microstation can shell a solid but I'm betting a suppliers model will be a mesh or surfaces so may be difficult to do much with. You will need to post the model or a sample if you want further help.
I mean the meshes which have originated from the STEP file. I don't want that kind of unnecessary lines. I want just an outline hollow model
I want to remove the unnecessary mesh lines and make it look like a simple cylindrical object
You can convert a mesh to a surface using the tool in the mesh utilities section. To be honest it might just be easier to remodel a simplified version. looks like it would be quite simple.
