When a view is rotated, is there a var or setting that can be tested that will say yes, the view is rotated?
if viewvar = rotated; then do something
Hi Tim,
TimSparks said:When a view is rotated, is there a var or setting that can be tested that will say yes, the view is rotated?
ACS is your answer. If the ACS is in the original position/orientation (first picture) you'll see it vertical and horizontal to you:
If you have your view rotated you'll see the ACS rotated:
Hope this helps.
José
thanks but no, I need something I can test in a macro file. a bas file.
is view rotated
In VBA, the View object does have a Rotation property.
Microstation BASIC has been obsolete for a number of years now. I would suggest taking a look into the VBA programming. There's an entire discussion board here dedicated to VBA/MDL programming, where you could probably get a lot of help.
MaryB
