Starting the move into CONNECT. Simple question - How do I drop a linestyle ( like the included "batten")?If I key in "drop linestyle" or pick the tool I get an "Element not valid for tool" message.I've tried this with a few different linestyles, no luck.
Tom F.
Hi Tom,
I can reproduce the issue. Key in worked for me in V8i SS4 when trying to drop batten line style but in CONNECT I get the same alert message. I suppose is a Bug but I will confirm with development.
Good morning I have the same problem, in microstation CE update 11 ita drop LineStyle works only with the "diamond" style and with the others no. attached the dgn and rsc file.Drop Linestyle.zip
kind regards
