I just heard were going to adopt a new datum in Australia its called GDA 2020 , the old datum GDA 94 is now 17 years old and at 7 cm per year continental drift its time for a new datum.
V8i ss3 doesn't have this datum available in the library of datums... does SS4 have this? Does CE have it?
Will Bentley provide a stand alone file to be able to import it into Microstation to allow us to have the new datum when we need it? ( local government will want us using it within 1 - 2 years and all government spacial data will be in that datum).
Will the update file from Bentley work will both CE and V8i SS3 to SS4?
Does current Bentley Map have this datum? If so can somebody export the datum so we can add it to our datum (folder? ) so Mstn V8 etc can find it?
I know we should probably post this in the Mapping forum but I'm wanting to reach as many Microstation users as possible
thanks mark but that article requires one to have and use Bentley map and if it was that easy then Bentley could just provide us V8i users with the replacement file(s)... looks like I have 2 more years to learn Acad, better that than learn CE... at least everything works in latest acad and doesn't take forever to load and if you have to use ribbon then may as well go over to acad. even if my relationship with Bentley has been almost 30 years.... maybe its finally time to go over and embrace the dark side...
Lorys
I'm not going to try and defend the complete hash Bentley has made of CE but the latest release U10 does at least have some performance improvements and you can use the classic dialog and toolbars to get closer to V8i. It is the first version of CE that I would consider deploying. I'm also fighting the battle as we use Revit on most of our projects post planning so we get AutoCAD as part of the subscription so why would you pay twice for Microstation? It's not an easy question to answer.
You'd only need map if you were creating a GCS. If the files are provided (which they will be, either by Bentley or fellow users) all we need to do is either update the gcs library or add another variable to point to the custom one. Not providing a workflow for GCS update for v8i products is tantamount to discontinuing all v8i support in Australia in the next couple of years, which would be lunacy...
Although CE has its issues, it is still far superior to acad IMO (and I use acad 2019 regularly).
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Bentley is going to be discontinuing V8i support in a couple of years as it is, aren't they?
MaryB
Just as you brought this up, support for pre CONNECT versions of MicroStation will be diminishing from mid 2019
https://www.bentley.com/en/desktop-applications
