Microstation Connect edition does not show edge lines correctly, when using Hidden line- presentation and cached-visible edges settings in references. View shows edge lines, which should be hidden. If I change visible edges to Dynamic, this problem disappears. Using Older Microstation SelectSeries 3-version shows this reference view correctly.
Does anyone else have this same problem? I'll attach exampledng file and word-document to this post.
DOCXcached and hidden line problem.dgn
Best Regards
Arttu Rankinen
As a workaround I found that if you combine the elements into a single solid the visible edge display caches correctly, but only shown in one color.
For tool info please see Unite Solids Help.
Thank you both.
-Arttu
