For YEARS I have wanted the ability to place a note with a line beneath the first line of text with the rest of the note underneath that line. I know a few workarounds, and ways to make something LOOK like that, but there has been no way to create that sort of element as a true note from a dimension style.
Has that ability been added to CONNECT?Could it be added?
Thank you.
MaryB
In CONNECT the text editor is a little more robust, you can reference the images below.
Once the text is entered in the editor you can select portions of the text and change certain attributes like italic,bold, and underline.
The note can then be placed normally.
In V8i you could not select a portion and apply an underline, as it would be applied to all text.
MaryB said: I know a few workarounds, and ways to make something LOOK like that, but there has been no way to create that sort of element as a true note from a dimension style.
what process were you doing before? Dropping from multiline to multiple single line text?
No, I've been able to underline a portion of a piece of text for years - in V8i. That's not new to Connect.What I'm looking for is the ability to create a dimension style that would place a note like this:
Not text with an underline, an actual note leader that goes under the first line of text, while the other lines of text show below that leader line.
Dimensions have been able to place the leader under (ALL) the text for some time:
What I want (and have wanted for years!) is a dimension/note style that would place that same line under the FIRST line of text instead of the LAST.
As it is, I have to place an note configured as shown in the second image for just the first line of text, then place an independent piece of text below it for the rest of the note, or I have to place plain text and draw a line string in place of a real note leader. I can't create a real Note that looks like the first image.
We use this style constantly. I've tried to encourage people to move toward the available note options, but everyone loves this look and refuses to give it up. Truth is, I like the way it looks too; I just don't like the extra work it takes to create or modify the darn things. I've seen requests for this type of note on these boards going back over ten years - I'm not the only one who would like this option.
I guess I was hoping that, will all the other updates coming in CE that Bentley might have addressed this, and given us a little more flexibility in Dimension/Note styles.
I believe Enhancement # 248314 had previously been raised to include this operation within the Place Note tool if that is what you were wanting.
"Place Note tool should allow multi-line text to be placed above and below the in-line leader."
Answer Verified By: MaryB
That sounds like what I'm looking for. Is there any indication of a timeline for that enhancement?Thank you.
mary stupid question without notice...would a really big line spacing between text lines in a custom text style- dim work?
what if you dont put any text just a space, then add the text later ?... nah that is probably what you doing to get around it now... what about change the lower margin to a big negative number in the notes dim style.... or big positive?
Lorys
