Dear Forum,Using MS Connect 10.10.00.23 to publish iModel[s] and the process hangs and/or crashes. the total amount of files its trying to publish totals around 930mbs in 20 references. Anyone see this as being a problem?Any hints to get around it i can try?Andi
At what point does the crash occur? I would suggest testing to see if a reference is the issue by turning the display off.
Unknown said:Using MS Connect 10.10.00.23 to publish iModel[s] and the process hangs and/or crashes. the total amount of files its trying to publish totals around 930mbs in 20 references. Anyone see this as being a problem?
Seeing how large the files you are working with are it may be hard to share.
I would recommend filing a Service Request to further investigate the issue.
Some of your references are DWGs i bet. We have the same issues when DWGs are attached, turned off or not. The same files publish fine in SS4.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
No DWGs but its possible some are exports of DWGs to DGN. Would this affect this specific problem?
Hmm not too sure
Have you tried only publishing a few and noting where it fails?
i tried the largest and still it fails quite a few times. Didnt know if there were known issues i could check for?
