My basic problem is taking a set of data points (latitude, longitude, elevation) and inputting them to microstation CONNECT, then exporting them to google maps or earth. I have played around with using a text file using “place point, point acsabsolute” and it has not worked yet. Any ideas on how to do this?
There is a built in tool to import coordinates:
https://communities.bentley.com/products/microstation/w/microstation__wiki/14101/how-to-insert-3-points-xyz-co-ordinates-into-a-design-file
Once the points are in the file you can export to Google Earth:
https://communities.bentley.com/products/microstation/w/microstation__wiki/16907/export-dgn-data-to-google-earth
