whenever I attach a heavy 3d models to a 2d drawings and when I change the visible edge from dynamic view to cached view in reference dialog box, it takes long time to change to cached view. Is there any quick way or setting to change the visible edge view ?
Maybe a faster computer?
~HTH
John.
yep
Narayan,
Are you on ABD CE3?
Are you attaching the 3d model into the 2d Drawing or Sheet models directly? Or are the 3d models being attached to the master design model?
is your update method set to automatic?
How much RAM do you have?
Are the usual recommendations like turning off autoannotation being followed? Also, CVE settings should be fast, not exact.
Are the ref attachments dwgs?
What is ABD CE3? I am using microstation v8i select series 4.
Yes I am attaching the 3d model from design model to sheet model directly.
How to set the update method to automatic?
I am having 16gb ram.
How to turnoff autoannotation?
Yes the CVE settings is set to fast.
I am using a pc of 16gb ram.
Go bigger, quad processor with 64gb ram.
