whenever I attach a heavy 3d models to a 2d drawings and when I change the visible edge from dynamic view to cached view in reference dialog box, it takes long time to change to cached view. Is there any quick way or setting to change the visible edge view ?
Narayan Kavinatamai said:What is ABD CE3?
ABD CE3 is AECOsim Building Designer Connect Edition Update 3.
Narayan Kavinatamai said:How to set the update method to automatic?
Help it's always a good place to look for tips.
You can change the way your reference is loaded in References dialog, Visible Edges:
Dynamic is automatic and don't help if the model is large and/or complex. But you have Cached that has full control how you want to load your reference.
José
Thanks for your reply Jose Pinho.
Is there any way that I can keep cached as a default setting instead of dynamic.
Narayan Kavinatamai said:Is there any way that I can keep cached as a default setting instead of dynamic.
In V8i not possible as far I'm aware, but since Microstation Connect Edition Update 5 you have more control over this settings.
See here.
