I want to attach reference file using key-in command in a batch process command file. Both “RF=” and “reference attach” are properly working with coincident view (*) without any user input of pressing “Ok” button in the reference attach dialog box. But for the “coincident world” view (#), it needs a user input of pressing “Ok” button in the reference attach dialog box. I need to attach reference with world coincident system. Can anybody reply how I can use the command for world coincident attachment without pressing “ok” button in the dialog box?
I just tested this using
rf=g:\test2.dgn,,,,#
This attached without asking me to press OK. Do you have the right number of commas to avoid it asking you for other options?
Thank you for your quick reply. I was using with a model name and a nesting depth also, then it was asking for 'ok' response. Now I will check again without that options. Anyway thank you for your response, I will check again.
rf=g:\test2.dgn,default,test,test,,1,#
This also works for me.
I think you checked in key-in browser. It was working properly for me also in key-in browser. I was asking about Batch process command file, it was not working with out pressing ok button when we used this in batch process command .
Yes. I was. I've just tried with a batch process with the same keyin and it worked for me
