ref: https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/120604/design-constrain
Good Morning,
Is there a way to determine Depth of Cover from the top of pipe barrel to surface and or is there a version of the tool, 'Measure Cover To,' in MicroStation CONNECT Edition Update 8 - Version 10.08.00.37?
Thank you,
Aaron
Hello Aaron,
Are you are asking about SewerGEMS, or MicroStation?
Hi Jesse,
I read on a Bentley thread how it's possible to measure the vertical distance from top of pipe to surface using the 'Measure Cover To' tool in SewerGEMS? I'm wondering if it's also possible to accomplish this type of measurement in MicroStation CONNECT Edition Update 8 - Version 10.08.00.37.
Thank you for your time, sir.
Hi Aaron, just to be sure, you're referring to measuring a drawing of a pipe and ground, in "plain" MicroStation, right? (not SewerGEMS integrated with MicroStation). The tools in SewerGEMS are highly specific to SewerGEMS and would not be available in MicroStation. If you are asking only about MicroStation on its own, I will move your thread to the MicroStation Forum where someone can assist you with making this measurement.
Yes, this is correct. Apologize for the confusion. I'm inquiring about making this measurement in MicroStation solely.
Thank you.
Hi Aaron, no problem. Thanks for confirming. I have moved your post to the MicroStation forum, where someone should be able to help you.
