Projecting a B-Spline Curve from Formula to a Circle
Hi All
I recently just discovered the tool to generate a B-spline curve by formula in Microstation V8i. It works great.
The problem I have now is to fit this curve into a circle of certain radius. I wonder if there is any tools for doing so.
I am actually working on a wheel flat problem in railways which is like a Haversine curve (to represent the flat). I attached a picture for clarity...
Thank you!
