Today I seem to have accidentally turned on the "Super-Undo" function.
Whenever I hit CTRL+Z to undo a mistake, it is undoing more than just that one action. It's not undoing EVERYTHING, but it's going back to some (apparently) random point in the design file. CTRL+R (Redo) redoes all those steps. There is no walking back or forth - it's all being undone/redone in one big sweep. This is even "working" across activated reference files - work done there is part of the undo/redo collection.
I have not set a mark and I am not Undo-ing to Mark. And it's not going back to the same spot every time. But it's definitely wiping away more than a couple of minutes work.(Note: while I am using Power InRoads, I am not doing any design whatsoever, nor am I using the InRoads tools at all. Just plain drafting)
Has anyone ever seen this before?Thank you.MaryBPower InRoads v08.11.07.615
Never seen that. Dumb Stuff- Have rebooted your PC?
I have now, and that seems to have fixed it.That may be the strangest thing I've seen all year...
MaryB
I've always had a knack for those type things. Seems all this expensive software is not totally debugged, seems like it used to be. We expect to do the same operation and get the same results, logic, right. When this fails to happen it can be the software has malfunctioned. Just wait til you're forced to Connect (don't do it until you must), it's as buggy as a 3 day old piece of fruit.
It is still doing this in OpenRoads Connect Edition 10.10.21.04. Did you ever find a solution for it?
Hi William,
From what ive been told that is because the buffer stores everything whenever a corridor processes and probably maxes it out. Maybe someone here knows if there is any way to increase it?
When it happens to us we urgently redo so we dont lose hours of work and live with it...
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
