Today I seem to have accidentally turned on the "Super-Undo" function.
Whenever I hit CTRL+Z to undo a mistake, it is undoing more than just that one action. It's not undoing EVERYTHING, but it's going back to some (apparently) random point in the design file. CTRL+R (Redo) redoes all those steps. There is no walking back or forth - it's all being undone/redone in one big sweep. This is even "working" across activated reference files - work done there is part of the undo/redo collection.
I have not set a mark and I am not Undo-ing to Mark. And it's not going back to the same spot every time. But it's definitely wiping away more than a couple of minutes work.(Note: while I am using Power InRoads, I am not doing any design whatsoever, nor am I using the InRoads tools at all. Just plain drafting)
Has anyone ever seen this before?Thank you.MaryBPower InRoads v08.11.07.615
We have experienced it as well in Microstation CONNECT. Has there been any update?
Best Regards,
Anupama
Is this after a long session?
Mark
3 years later and the bug still isn't fixed
Nigel Vanlaethem said:3 years later and the bug still isn't fixed
Do you have any test case? In what product and version do you experience the issue? Different products and versions were mentioned in the past.
Jan
Hello, I am using the microstation CE version 10.16.02.34. Today this happened when I put a assosiative linear dimension. After which I moved 1 one of the lines. I moved it a second time. Then I hit ctrl+z and it went back to before placing the dimension. I used ctrl+r and that did work in steps. At this time it's working correctly.
